Tyre Pressures
Tyre Pressures
Post by garyf » Thu Sep 12, 2019 2:12 pm
Hi All
I've done a quick search on this forum but can't find the answer.
I'm running 185/70 x 13" Tyre's with 6J Alloy wheels on my Tiger, what would be the recommended Tyre Pressures front and rear for normal everyday use?
Re: Tyre Pressures
Post by Brad1380 » Thu Sep 12, 2019 8:19 pm
Never an easy one that, best buy a digital thermometer then after a run take readings on the outside and center edges, outside edges hotter air add some, center hotter let some out.
That's they way I've done it anyway.
RR
Re: Tyre Pressures
Post by garyf » Fri Sep 13, 2019 8:50 am
Ok thanks, I don't suppose the original Tyre Pressures quoted when the car was new are any good now due to the radial tyres?
Just out of curiosity what were the specified pressures Front & Rear for the Tiger with Cross plies fitted?
Re: Tyre Pressures
Post by ksherlock » Fri Sep 13, 2019 2:14 pm
For the original RS 5 tyres ( 5.90 x 13 ) , the recommended pressures were 26 psi all round. This was supposedly up to 110 mph ! I don't think Tigers could do any more than this speed anyway, but if they could then the pressures should be raised to 32 psi.
Re: Tyre Pressures
Post by garyf » Fri Sep 13, 2019 2:49 pm
I've got mine at 28 PSI all round at the Moment, so something like correct I reckon?
Thanks for the feedback :D
