Page 1 of 2
CPP Custom power and paint
Posted: Sun Oct 26, 2014 3:12 pm
Has anyone had experiance of these chaps for engine work?
http://www.custompowerandpaint.co.uk/
Posted: Mon Oct 27, 2014 6:15 pm
Anyone?....engines are not cheap!
Posted: Mon Oct 27, 2014 8:44 pm
by redbaron
Hi Brad,
not had any dealings with them myself,but what sort of spec and cubic inch engine size are you thinking about.?
Standard 260,289,302,or modified or a Stroker engine?
David
Posted: Tue Oct 28, 2014 1:09 am
I was thinking of 302 upwards, depending on cost....horse power gets expensive quickly!
Posted: Tue Oct 28, 2014 2:54 pm
Real steel have a good reputation for providing a range of engines to varying specs depending on your wallet.
Posted: Tue Oct 28, 2014 5:11 pm
I was going to get quotes from both, though Jez at CPP seems to be highly regarded by the cobra/ mustang brigade.
The trouble is when you start looking at engine specs its easy to end up looking at the higher end stuff like forged 347 units )
Opinions and balls of string
Posted: Wed Oct 29, 2014 5:04 am
by Tom_HRO260
Hi Brad, I can't profer any information regarding the UK based engine builders I'm afraid and in choosing a build spec, you'll no doubt find opinions vary greatly (which in itself seems a particularly strong Tiger-trait...)
For what it's worth, I sourced mine from a builder in the States mainly because the company had a strong reputation amongst the Cobra community, and to be fair, the AUD against the USD at the time was well placed. I don't know how the EUR/GBP is against the USD nor what you would expect to pay freight wise (I had a contact for airfreight so it's not a fair comparison), but a reputable US build might be worth considering. I've always thought Tomaselli's engine sounded good and strong in his youtube clips - perhaps he has some advice. I personally didn't go the stroker option but instead went a 4.125" bore. Something a bit different but I'm extremely happy with the results.
One thing is guaranteed as you've already stated - horsepower can get expensive. Personally though, a good build over outright HP is always going to be money better spent (in my opinion).
Good luck in the hunt, Tom
Posted: Wed Oct 29, 2014 9:41 am
by redbaron
Hi Brad,
As Bob has said in an earlier posting,Real Steel in the UK do have a good reputation for engines that they supply.
The downside to buying from the States for us would be the warranty,if it goes wrong long way to ship back :(
You say that you want a 302 above size engine,the next will be 331 Stroker unit,Real Steel do have these,maybe worth a look.
David
Posted: Wed Oct 29, 2014 9:44 am
Can i ask a stupid question, whats the differeance between a 331 & a 347, is it bore or stroke?
Posted: Wed Oct 29, 2014 9:54 am
by redbaron
Brad,
the difference comes from the Stroker kit,i.e crankshaft and rods, to achieve the capacity increase.
Posted: Wed Oct 29, 2014 10:13 am
How about a supercharger? You can keep engine spec fairly normal & run 8psi safely. Loads of torque & 40% power increase from standard.
Alloy headed 302 with Rotrex blower = 490bhp & 570lb torque
Posted: Wed Oct 29, 2014 1:23 pm
Bob if i was in the UK i would think seriously about that, but here its a no go due to insurance limitations.
Posted: Wed Oct 29, 2014 6:07 pm
How did Mad Max get away with it???
Re: CPP Custom power and paint
Posted: Thu Oct 30, 2014 8:08 pm
redbaron wrote:Brad,
I was just wondering if the 331 has an extra rebore in hand compared to the 347?
Posted: Thu Oct 30, 2014 8:13 pm
by H, Sunny 65
Brad.
Its all done with shorter rod's. It's like magic, the bore stays the same.
