Rev counter problem
Shindles
Rev counter problem
Post by Shindles » Thu Mar 12, 2020 11:02 pm
Just fitted a FAST distributor to my Tiger and the tachometer will no longer read obove 2000rpm.
Anyone know if the tacho can be modified to work?
Re: Rev counter problem
Post by Brad1380 » Fri Mar 20, 2020 7:17 pm
You may have to convert the tacho from RVI to RVC input, give Speedy cables a call they may help you out.
Post by Brad1380 » Mon Mar 23, 2020 12:37 pm
You may get away with a MSD 8910 tach converter, someone else may know if it will work.
Post by Brad1380 » Sat Mar 28, 2020 7:19 pm
You can try adding a second loop to the tacho wire.
